delta pro 5005 ALARM
    I would like a wiring diagram for a 92 honda accord/99 venture for a delta pro-5005 security system " (i have 2 alarm, these been sitting in my garage for a year and half ). this system has a ignition immobilizer, remote start, basically everything. If no one has anything like this, could you refer me to somewhere I might find one?
    INCLUDES:
    MAG 6 Tone 125db Siren
    Main Wire Harness
    2 TWO way Pager Remote
    Emergency Override / Programming Switch
    Dual Stage Shock Sensor
    Owners & Install Manual
    RED STATUS L.E.D.
    Hood and Trunk Pin Switch
    Protected by Window Decal
    Limited 2 Year warranty from Delta or through Our Company
    Includes One Ultra Small FIVE Button Multi-Channel Pager Remote
    One 4 Button Standard Remote
    0.7 or 3 Second Door Lock Pulse (Programmable)
    Code Learning Receiver
    Anti-Scan Technology
    Alarm Pre-Warning
    Defective Zone Bypass with Warning Chirps
    Remote Panic
    Starter Disable Protection (Relay Required)
    On-Board Flashing Light Relay
    LED Status Indicator (Plug-In Design)
    Protected Valet/Programming Switch (Plug-In Design)
    6-Tone Mag 125dB Electronic Siren
    Passive or Active Arming Mode (Programmable)
    Door Lock on Passive Arming (Programmable)
    Auto Lock/Unlock through Ignition (Programmable)
    Graphics Display Armed or Disarmed State, Zone Violation, Vehicle Running After Remote Start, and Valet/Service Mode
    433 MHz Transmitter Frequency for Less RF Interference and Added Reliability
    Penetrates through most Cement Structures,Movie Theaters,Malls,etc..
    Digital Transmission Format Permits Real-Time Instant Confirmation of Arm, Disarm, Start, and Intrusion
    Valet Button Operates as an In-Vehicle Call Button to the Transceiver
    On-Board Relays for Easy Installation
    Selectable Engine Speed Sensing: Tach Learning, Tachless, or Vacuum Operation
    Gas or Diesel Engine Operation
    Hood Open Safety Circuit.The Unit will not Remote Start if Hood is Open or Ajar
    JDM H23 VTEC PROJECT
    JDM H22/F22/H23/B18 PARTS FOR SALE
    91 Accord Sedan Ex Mulberry Pearl Red (GAVE IT AWAY) Turbo
    91 accord Ex wagon Green (SOLD)
    92 Accord Lx (SOLD)
    92 civic sedan Lx (SOLD)
    93 accord Ex wagon Frost White (parting out: SOLD)
    07 Fit SSS (Traded)
    07 FG2 Si Sedan (Traded)
    05 Honda Pilot EXL Pearl White
    97 Honda Odyssey LX W/Sunroof Pearl White[/B]
    http://1facewatch.com/
    Looking for a referral and planning on switching to Cricket Wireless
    ive done so many of these cars....
    at the ignition harness you can find:
    12volt constant- white (+)
    starter- black with white stripe (+)
    ignition- black/yellow (+)
    accesor- yellow (+)
    for locks go to the drivers kick panel, youll see a gray 2 pin plug usually wrapped in blue tape and not connected to anything
    lock- black/white (-)
    unlock- black/red (-)
    parklights- red/black (+) fusebox, also on a harness to the right of steering column.
    to the left of the column youll see a brown plug and a green plug, youll find:
    door trigger- black/white (-) in the brown
    trunk trigger- green/black (-) in the green
    for the brake wire its right on the switch
    brake- green/white (+)
    and finnaly at the distributer
    tach- blue (AC)
    FA1
    355
      http://www.cb7tuner.com/vbb/showthre...t=alarm+wiring
      another
      sometimes for lights i go down to the rail where the locks are near and get them there, also i get the brake switch there but thats for remote start.
      Retro!
      Hater
