Stereo (w/ CD Player!) Removal
    Yo,
    Regrettably my 93 EXR came with the CD player option. Evidently this means that the gold hex screws above the ashtray holder (shown in this DIY and in my Haynes manual) don't exist.
    Any tips on how to get the deck/cd player out would be great
    93 EXR
    In the works ^.^
    Todo:
    Blower Unit replacement
    Climate Control Knob replacement
    Deck install
    SRI install
    New Brake Pads
    Rotor regrind
    Wheel polishing
    New struts (?)
    New springs
    That doesn't make any sense.
    I just took mine out last weekend, and those bolts you're talking about are the only things that hold in the radio and the tray thingy-ma-bob. I have the service manual, and there aren't any other bolts, screws, clips, braces, or whatever in the diagrams.
    If you can't find any other metal objects holding it in, then consider the possibility that the dude-ski who had it before you super-glued the bastard in.
    1991 Honda Accord EX (Canadian)
      hmm...provide us with some pictures man, this sounds wierd...
      i'll be able to help as soon as i get pictures
        fuk that, go from the back of the deck, take out the 2 8mm screws or phillip that holds it in, and it will slide out.
        Retro!
        Hater
          @Cats:
          Nice ride ^.^ Regrettably, since I have a CD player, the bolts don't seem to exist.
          Pics:
          Where the bolts should be
          A shot I took from behind the stereo.
          I suspect that one/two of these bolts has to come undone, but how the hell do I get them out? No screwdriver I know of it going to fit in that space.
          (Reference pic showing where the behind shot was taken from)
          [edit]
          Hit reply too soon.
          Thanks for the help guys![/edit]
          93 EXR
          In the works ^.^
          Todo:
          Deck install
          SRI install
          New Brake Pads
          Rotor regrind
          Wheel polishing
          New struts (?)
          New springs
            I had the cd changer option in my cb7.. so I thought I was screwed to.. but a 10mm or 8mm can't remember which one joint socket with extension is all you need to get those two gold bolts out.
            always out numbered never out gunned..
              Hmm... Imma have to find myself an 8mm socket, then.
              Thanks!
              93 EXR
              In the works ^.^
              Todo:
              Deck install
              SRI install
              New Brake Pads
              Rotor regrind
              Wheel polishing
              New struts (?)
              New springs
                yes there are 2 8mm bolts 1 on each side, you will need a 8mm socket and an extension also, you will see them close to were the bars which are behind the radio, when u look behind the radio they face down towards you, they are gold in color, you just have to look up at an angle and you will see them, then once you take them off, the radio slides out.
                  wow....now that's one funny thing here..
                  if there are no bolts on that place, so....only the bolt from behind hold the cd player?
                    yup there are only 2 8mm bolts the hold the radio from behind
                      Since he has the CD Player its a different bracket, i used to have the OEM CD Player on my CB.
                      I'll try to scan/post the directions.
                        Look at illustration 1 and 2.
                        1. bracket A has 3 (8mm)
                        Then it has 2 more screws (8mm) at an angle as shown above.
                        2. the 3 (8mm) screws are going to be in those slots.
                        Also, If u have taken out all those screws and it still doesnt want to
                        come out, then i guess you are going to have to take off two more screws (8mm).
                        They hold the radio/cd player assembly to the brackets.
                          Ahhh ^.^ I get it now. Thanks Jak!
                          The 3 bolts that are usually holding the thing in are gone, so it looks like I'm going to have to get out those two stupid 8mm bolts from the side. On the plus side of things, the bracket assembly is much simpler than I'd guessed it would be, so this shouldn't be too hard.
                          Thanks again! (Will post back when i have the damn thing out.)
                          93 EXR
                          In the works ^.^
                          Todo:
                          Deck install
                          SRI install
                          New Brake Pads
                          Rotor regrind
                          Wheel polishing
                          New struts (?)
                          New springs
                            Awesome, Jak!
                            Now that's an excellent diagram u got there!
                              thats pretty much what I had to deal with when it came to pulling my deck with the changer option. believe me people it may look hard but its a snap with the right extension.
