Help !!!!!!
    Help !!!!!!
    I got a new CD player (KOSS) and I tought i could install it myself. I cut the wire directly behind my old cassette player and start wire<--->wire connection.
    I tought it was good but the CD player don't work.
    Can somebody tell me or post me a website off wire<-->wire connection (what color with what color)
    I don't want to pay someone to do it :\
    THX
    umm, you're gonna have to get a wireing harness that goes from the radio to the factory wiring harness, and match up all the colors that way... you can't just cut 1 wire and expect it to work... you have to hook up speaker wires, power wire, ground wire... constant power wire memory wire, maybe some more
      hmm, do you have the antenna plugged in?? most aftermarket cd players will not turn on or function at all, unless the antenna, or even a stub is plugged in
        buy a harness anywhere for a honda. you'll figure it out.
        Formerly: sheisanonymous
          Grab a repair manual (if you don't have one), look at the wiring diagrams, and figure out which wire goes where .. . Or, wait a few days, and I'll write them all down when I put my new deck in ...
            and solder <---(SPELLING?) your wires or get a good crimp dont just twist and tape them i wouldnt solder to the factory harness though because if you decide to change head units you're going to be cutting and addind and its going to get messy. Why didnt you get the harness plug?
            1993 Accord EX
            2011 Subaru STi
              Check out this site:
              Go to www.the12volt.com they have a diagram of vehicle wiring. I would give you the exact page but you must create a user name and password.
              Why? Because... Life Happens @ 4500 RPM
              Frost White CB7 Member 31
                solder the factory harness back on(match the colors they way they were) and get a honda harness at walmart and it will come with a diagram.
                ~ Viva la Roofnips ~
                2006 Evolution MR 13.008 @ 106.7
                2006 WRX Sti (still breaking it in)
                1990 Honda Accord LX-T 15.6 @ 93
                  stock decks should have the wiring diagram on the top. but hell with a cheap ass $6.99 volt meter or even a test light you can figure out whats what power wise. then just use a small speaker to determine which wires goes to what. thats the simplest way I can think of doing something with limited tools or maybe for first time installers.
                  always out numbered never out gunned..
                    get a harness and a manual and go from there
                    RIP lilblue
                      Since you already cut it, just get a test light to get power and igntion. Ground should be easy, its black i believe. Speakers are pretty easy too, they are twisted wires. Just get a battery and pop them. Polarity wise, red and blue are positive, gray and brown are negative.
                      Easy huh
                        go buy a harness.. i bought mine from walmart for less than $10.. makes life easy
                        www.aznkid.com
                          On another note koss doesnt make very decent products! especially when you can buy a pioneer or jvc for the same price! IMO
                          My grandpa bought one and returned it three times till he finally broke down and bought a clarion. And it worked perfect!
                          WaC!
