no bass?
    no bass?
    my subs are on but they dont thump with both rca jacks plugged in, when I pull one out i get alot of bass from only that one side thats plugged in, whats the problem, thanks
    R.I.P
    Sounds like your RCA's might be fucked or plugged into the wrong plugs?
    I'd eat a baby for free. I'm hungry, dammit!
      Possibilities bad rca jacks, bad channel, ect... Does your amp have a built in crossover? Need more info.
        i believe you have the positive and negative wires switched on the connector for the subs
        Members Ride
          K, dif. than what every1 else is saying, did you build your box yourself? Cause I built my own box and I barely heard anything at first and I was really pissed till I turned the channel to all the way to right or left and it sounded incredible. I found out that I had not siliconed between the divider and a tiny bit of air went between the two subs and unbalanced them when they were both on so after I siliconed the sub-sections (excuse the pun lol) it sounded fine. Otherwise check the amp to make sure you aren't overloading it, turn the level all the way down then turn some music on and slowly turn it up to see if it is cutting out at a certain point. my .o2 cents
          My 91 Accord F22B DOHC MR
          My 1996 Civic Ex H23A VTEC MR
            BlackCB7 hit the nail on the head.
            Your subs are out of phase...what this means is that for a given bass note, one sub moves out and the other moves in...this equal and opposite movement creates no bass at all, cuz no pressure is created.
            You need to switch the phase (+/-) of one of the subs only. If you paralleled the wires inside the box, you need to take 1 sub out and switch the wires. Good luck, but i'm sure this will help a lot.
            Mark
              Mark
              x2
              YouTube Clicky!!
                Mark
                That is only if he has 2 subs which we don't know but yes that could be it.
                  Assuming 2 by the use of the word Subs as opposed to sub in his first post.
