i have a lx and im tryin to add a audio control to the steering wheel.dose anyone kno how to remove the wheel or maybe how i can wire the unit without removing it?
06 accord need audio help
are u talking an after market unit or stock i personally would recommend a wireless remote less hassle and u can mount it anywhere u see fit plus u have a 06 i wouldn't want to mess with airbags and such for a wired remoteOriginally posted by killahsi2003i have a lx and im tryin to add a audio control to the steering wheel.dose anyone kno how to remove the wheel or maybe how i can wire the unit without removing it?
Yea, what he said. You don't want t blow your air bags. That would suck BIG time!Originally posted by ghettogeddyare u talking an after market unit or stock i personally would recommend a wireless remote less hassle and u can mount it anywhere u see fit plus u have a 06 i wouldn't want to mess with airbags and such for a wired remote
"Wise people treasure knowledge, but the babbling of a fool invites disaster" Proverbs 10:14
there's a small cover on the bottom of the steering wheel, take that cover off, then disconnect the yellow connector. there are two torx screws one on each side of the steering wheel. take those two torx screw off, take out the airbag ass'y. then there should be a nut holding the steering wheel on, take that nut out, and fight with steering wheel to get it to come out. good luck and make sure that you do this with the key out of ignition. make sure when you touch the airbag, wait at least 5 min. because the airbag is still hot.
