2 12inch subs problem..i don't get it ?
    okay i got 2 hollywood subs in a box that i bought for $50 bucks
    they sounds aiight nothing killer or nothing
    so i open them up and i only see one speaker connected and im like WTF?
    so i hook both up to my amp correctly and they sound like SHIT!!! literally
    so i disconnect the one that was disconnected and it hits pretty good
    i don't get it ?
    why is only one kicking and it sounds good
    heres' the amps
    it's just 2 12''s no holes or nothing
    can i change something to make them sound louder or
    make sure they both are connected ? to get more power out of them?
    or what?
    Ride: 2002 Lexus IS300
    mono sub? poor wiring? poor quality speakers? wrong box? bad subs amp combo? Did you test them first, they could be completely blown. or one blown. or you amp if fryed. who knows.
    What kinda amp?
    I cant Slam further. The ground refuses to get any lower.
      how powerful is your amp? it might be trying to put the same amount of power you had going in one sub into both.
      plus the sub on the left in the pic looks like the lining has started to come away. is it sealed properly?
      And please, for the love of God, type like a human being!
        try wiring them together then you'll be using dual ohms. this is pretty complicated so make sure you get it right:
        1. wire the positive end of one sub to the positive end of the amp
        2. wire the negative end of the OTHER sub into the negative end of the amp
        3. wire the negative end of the FIRST sub into the positive end of the SECOND sub.
        you should now be runnin dual ohms and it might sound better. if it doesn't your sub is probably bad.
          dual ohms? i dont know what you are talking about, the wiring your talkin about is called series.
          Member Ride Facebook
          XBOX LIVE = RedDragonsFool
          SOLD MY CB JUNE 16, 2009
          For Sale Thread
            real simple.. They are out of phase Reverse the wiring on one of the subs + and -
              yeah im gonna try to mess with it soon
              but yeah it's a 1000watt old pyramid amp
              it's doing aiight
              but yeah if i bridge the subs sounds FUCKED UP
              i haven't tried dual ohm or whatever yet
                dual ohm... dude... that is nothing, it doesnt exist yo. dual voice coil is probably what you meant, but the wiring you described as dual ohm is just wiring the subs in series. parallel setup would be postive to positive and negative to negative. series is positive on one side negative to the positive on your next sub/voice coil (or whatever you are wiring in series) and then ground it.
                sounds confusing, check out the12volt.com if u need help wiring.
                For Sale Thread
                  Dual Ohms.....wtf, you mean 2 ohm? DVC is dual voice coils which depends on the subs you get. but you cant wire something to be 'dual ohms'.
                  The Wood grippin' - Mesh spinnin' Accord
                  My Ride | Cars from my trip to Japan | Japan II
                    my bad but couldn't i just wire it stereo?
                    like Left to one sub and right to another sub?
                    thats how i do my DJ setup
                    im not the best at wiring subs i just buy them the way the come
                      if someone can get me a diagram or a picture on how to wire them the best or different types etc? anyone i would GREATLY appreciate it
                        all depends on the resistance of each channel and the resistance of the subs
                        http://mobile.jlaudio.com/support_pages.php?page_id=160
                        http://www.crutchfield.com/ISEO-rgbt...rs_wiring.html
                        http://www.thedeepdiscount.com/Singl...il4ohmPair.htm
                          i think i need this one because im running mono from the headunit since it only has one output from the headunit for subwoofer
                          so yeah this one?
                            i did this one and it sounded like SHIT!!!
                              but idk what the ohms on the sub are shit lol
