capacitor what should i do
    i know this is a rookie question but im going to be buying some l7s for my cb soon and ive had a few people tell me i should get a cap which i dont really know to much about so id apprectiate it if someone could explain to me how its suppose to help thanks!
    96 Impala SS fund:$300
    http://www.cb7tuner.com/vbb/showthread.php?t=86795
    it acts like a battery, it helps when the bass hits hard, it keeps your headlight from dimming among other things.
    Click Me
      a 1 farad should be enough if you plan on running 1000watts or less.
      A cap stores energy and releses it as needed in a surge of power, it acts as a "cushion" between the amp and batt./alternator.
      MR Thread- I brought SEXY back- LOL
      If it jams, force it. If it breaks, it needed replacement anyway.
      Never argue with an idiot, they drag you down to their level and then beat you with with experience!!!
        I would highly recomend this if your running a high power system on your car so you won't suck all of the battery and alternator life from your car.
        Project EP hatch on the way
          Gat a 1 farad or bigger. The bigger the better.
            Sort of, after a certain point into won't matter. But yes big stuff, run a cap. It'll save your alternator and battery and all that good stuff.
            Proud owner of the only JJDM full 2.5" catback exhaust!
              I think the RMS on those are like 400+ watts and 1000W peak, you'll need a amp with like 800W to run it, and with that many watts you diffinately need a cap. 1 farad is good for 1000W
              edit: I think that may be the specs for a L5 the L7's are higher.
                thanks for all da comments the l7s push 1000 rms and 2000 watts peak. im getting closer to em cant wait
                  The bigger the cap, the more charge it will hold and the longer it will give out its charge. If the system is played at levels for a long period of time and the alternator cannot keep up with the current demands, then the cap will not be able to keep up either. An alternator upgrade will fix these problems. But, a high output at idle alternator is not cheap.
                    this is a good question. I was also thinking about this. but i only have 1 12 Pioneer and a Soundstorm 1500 Watt amp. and u said ur running 2 so id ont think ill need it for 1. well i hope not
                    TYPE R Big Build thread 25,000+ VIEWS!!!http://www.cb7tuner.com/vbb/showthread.php?t=123069
                    I feel like BIG MEECH! LARRY HOOVER! whippin work! haileliuah one nation under god. REAL naggas gettin money from the freakin START!
                      would a 170 amp alt, and like 1 cap in the back work? and btw u can put as many speakers in ur car cuz the only thing that drains the bat. is the bass so as long as u have no subs u can completly load ur car w/ speakers
                      1990 Accord EX 91200 miles..SOLD 2700$
                      out of the game for now but looking
                        l7 15's only push 1000 rms. i'd recommend a 5 farad cap with at least 4 gauge wire.
                        1991 Lx coupe........traded now I have nothing lol
