i installed my deck and everything was working fine until a couple days later when i started up the car. the ground wired started melting?? i did everything correct, could it just be the deck?? cause when my friend had it he spill some juice on the face. could that be the cause of it?
my ground wire started to smoke and melt??
1994 Accord Coupe LX BPU
1991 Galant VR4 #1395/2000 Sold
1990 Accord EX 4DR Sold
1990 Galant Base Model junked it
1991 Accord EX 4DR gave awayTags: None
a ground wire is just as important as a power wire.
if something draws and uses lots of current, it pulls it from the battery, but it has to get back somehow... through the ground wire to the chassis.
a fuse is nothing more than a wire. when too much current goes thru it, it heats up and burns out.
your ground wire acted as a fuse. for some reason it wasnt getting a good connection so a large amount of current was passing through a small wire. heat, and meltage.
my suggestion for repair: redo your grounds! take them off, sand them clean, and use a new clean bolt.
KUDOS KUDOS LOL I COULDINT OF HAD SAID IT ANY BETTER WOW.
i was thinking that its the deck, cause it did the same to my dad's truck now it wont start up any more. i mean it does but it'll burn the fuse right away.
chassis ground the deck. make sure everything is hooked up properly....what fuse is blowing?What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
yeah thats what i think too. the deck probably got mess up when my friend spill some juice the face.Originally posted by oozingmachismo2Sounds like that deck is shorted internal.
it was just the stock ground wire that connect to the plug.Originally posted by StockAccordYour ground wire might've been too small. try using some 4 guage wires.
honestly for a deck, it dont need a t hick wire.Originally posted by StockAccordYour ground wire might've been too small. try using some 4 guage wires.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
i'll probably get a new deck later on
yup sounds like deck is internally shorted, I had an old Pioneer do that one time lol I redid my harness 3 times and still had the same problems, then hooked up a different pioneer (with the same plug) and it worked fine...-Josh
91 Accord LX Sedan 5-speed (daily/project) - JDM H22A swap
91 Ford Ranger XLT Supercab 5-speed 2.3L (broke)
