I kno im not a beginner but i didnt kno where to post this. Im looking to buy a 2 step launch controller but i cant find any. does anyone have any suggestions?
2 step launch controller.
If you are using a program like crome for a tune, it is one of the features that you can have your tuner setup.
Beware of setting it too high however, it can cause a significant amount of wheel spin off the line if youre launching too high.2010 Taurus SHO - Livernois Goodies
well i kno your a turbo f-series. what did you set yours at or are you running this setup? im looking to put it on a t25 by the way.My cb7
h22a
5-spd lsd
Lord, grant me the serenity
to accept the things I cannot change,
the courage to change the things I can,
and the wisdom to hide the bodies
of those people I had to kill because they pissed me off.
MSD cuts spark. Anything with the ECU cuts fuel. A fuel cut is a BAD idea... I currently have it on my tune, but as soon as I get a nitrous kit, it's gone.
A fuel cut technically means you're running very lean until there's no fuel to burn. So for a split second, you're in the danger zone. For NA, for a brief moment, it's not bad. I'd usually do "bounce-bounce-launch"... 3500 for me. With turbo, it would be considerably more danagerous.
Get an MSD 2 step. When you cut the spark, that's it... just no fire. It's much safer. Of course, you don't want to sit there holding it, or you'll flood your cylinders... which could also be catastrophic!
Both the fuel and spark would be good, but I wouldn't trust them to always be exactly on.
