miss fire...
    miss fire...
    ok sometimes when my car is idleing...it miss fires really fast like almost stallls it seems like...and i tried to adjust my idle and it seems to not work i turn the screw all the way in notting happend turned it all the way out notting happend..lol...and now when i start my car in the morning it runs like its warmed up at 600-800 rpm's and sometimes 1200 rpms..could my throttle body be bad...?
    You should not touch the idling screw unless necessary.
    You prolly have a clogged fuel filter or your ignition wires are having a short.
    Check your spark plugs for any oil contamination.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      i have a fuel filter that i installed when i did my head rebulit about 27k miles ago.....and i think i need new plug wire...anyways but i didnt think they would pose to much problem i did at one time have oil in one my spark plug ports cuz when i did a valve cover gasket one of the like spark plug port gaskets got pinched and did not cause a seal and leaked some oil in the port...i cleaned it all out and bought bought new gaskets...
        mate i had the same problem as you did... i changed my fuel filter and my problem was fixed.... so maybe that could be you situation to.....
        Tommy Gun.... Gunning It all dA waY...
          i mean it seems like i just changed it...but ill do that and plug wires..soon
            try changing your distributor and the spark plug wire.
            My signature works perfectly fine.
              alight well do
                I, too, would vote for ignition system. How are your plugs? When was the last time you changed them?
                Anyways, plugs, wires, cap, and rotor are the things worth checking.
                1992 Prelude S w/swapped H22A
                  remove each of your spark plugs and check for oil... heavy oil around your spark plug is bad... it means that u may need new valve guides for those two valves. Look in your honda manual for more info on this. it's the spark plug page. good luck... i have to get new valve guides for mines same misfiring lol
                  Member's Ride Thread
                  Don't forget to cut holes in the box. Someone sent me a dead hooker one time, and that wasn't cool.
                  Bought From: AccordWarrior | CB7lx91 | DarkShadow707| Tn_Accords | H23CB7 | Jack_lee | Fatboy1185
                  Sold/Gave To: 90goldcoupe | CB7lx91 | Jas_r34 | F20accordturbo | BatmannamtaB
                    if everything else fails, do a compression check and check vacuum hoses, bad compression or a leaking vacuum line could cause a miss
