Hey i got a Faze tach, and i need to know where to hook this thing up at. can someone help me out maybe with pictures. or tell me which page in the manual for the 91 is it on. thanks
help connecting external tach
so cant see your stock tach? haha
engine bay, by the distribitor in the connectors. its the only blue wire. thats the tach wire. the harnesses are litterally connected to the distribitor.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Just find the wire behind the tachometer gauge.
no the indash tach still works, how do i get behind the dash to get to the gage? i already have a whole drilled threw the fire wall so i will probably be easier to go threw to the engine bay, thanks for the info.
So you said the harness plugs in by the distribitor?_____________________________
91 Accord F22B
It easier just to tap the line behind the gauge. Going through the distributor is the hard way. You have to take out the trim around the cluster and pull it out a little. Then find the wire color and splice it in.
i use to have the same tach and i had i wired in behind the stock tach... mine was 200rpms off though
. so i would go with the distributor, but if u decide to hook it up to your stock tach then it will be the green wire.
My cb7
h22a
5-spd lsd
Lord, grant me the serenity
to accept the things I cannot change,
the courage to change the things I can,
and the wisdom to hide the bodies
of those people I had to kill because they pissed me off.
