i just installed a 69mm tb on my turbo h22a accord.the car boost great but above 4000 rpm in 3rd,4th and 5th gear the cars power kinda dies off a little like it's not gettin enough fuel or air i don't know which one.i have to ease my foot off the pedal a little and it seems to make decent power when i do that above 4000rpm.the boost gauge shows it's makin boost but my a/f fuel gauge isn't showing anything past lean.sometimes my a/f fuel gauge shows nothing at all,at first i thought it was the gauge but i don't think that is what it is.i have a p28 ecu chipped with a crome pro base map/before changin tb.my question is has my ecu lost it's map or is this a map sensor problem.also at idle rpms go up and down from 750 to 1000 rpm,sometimes 500 to 1000rpm.my h22a is built with pistons ,rods,720cc injectors(10lb spring)
,all the good stuff.i want to correct this problem before i take it to the shop for tuning.i tried to explain the best way i could.
