Dash Lights
    Dash Lights
    when i turn the ignition key all the way (not starting the engine) all the lights turn on except the "Check Engine" light or the "ABS" light? are these supposed to be off or is there something wrong?
    alone in this game . ::My Ride My Way::
    burnt bulbs?
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      Check engine is for sure supposed to come on in the key on position. It will turn on and then turn off after a few sec unless you have a permanent code that sensed. Anyway probably a burnt bulb as mentioned. The SRS might come on I forgot I never paid attention to it on my car. Ill let you know whenever i drive my car tomorrow.
        how do you replace the bulbs? because i remember when i first bought the car ( 2 months ago) they went on.
          NAiL05 - Yep the SRS should come on too.
          tear2wo - remove the gauge cluster , kinda takes time but real easy.
            how do u remove the guage cluster and is that the only reason of why they're not turning on ? or could there be a problem with the engine or ABS themselves
              Should buy a manual it will tell you how to tear it down. Its just a shit load of bolts to pull the trim then unbolt the gauge cluster and the LED are right there behind it.
                If there was a problem they would turn on and stay on.
                Originally posted by xwade01
                This is pretty simple actually. Take the driver side air vent out, pop the buttons out for cruise, theres also 2 screws in the gauge cluster area that you'll have to remove. Pop out the two center vents, pull the ashtray, and right above the ashtray there is 2 screws in an upward angle. Now where you took out all the vents there is phillips screws in there. And everywhere I just told you too look theres phillips screws.
                After you get all the screws pulled out, drop the steering column to the lowest point. And CAREFULLY pull the dash bezel out. If your not careful that bezel will crack or break. Well anyway after thats off, theres 4 screws holding the whole cluster in its self, 2 on each side. Take those off, and carefully unclip the connectors and pull the cluster out at an agle slowly and carefully.
                After all that repeat process backwards to reinstall, you'll be fine!
                  thanks. i'll replace those bulbs and see what's up. keep u posted
