I have a 93 accord 10th anniversary and it had a wing on it with a brake light but it was disconnected. My friend came and disconnected my 3rd brake light and connected the light on my wing. Now on a gauge cluster it shows the brake lamp light always on. It could be that my friend connected it wrong or maybe a fuse????
Brake Lamp Question
is that a factory spoiler ?? just double check all the brake light bulbs. all my brake lights work and my car still shows a "brake lamp" light on. that's a common problem with these cars.
sold to: bootlegcb7, jhondayaaj
bought from : b3nsonx , *JDM_CB7*, bmxicansd, konig52r,
Slick_Nine, CB7_213
Originally posted by puertorico45My friend came and disconnected my 3rd brake light and connected the light on my wing. Now on a gauge cluster it shows the brake lamp light always on. It could be that my friend connected it wrong or maybe a fuse????
so your 3rd brake light is disconnected, maybe that's why the dash light for the brake lights are on.
Yeah the center high mounted stop lamp or CHMSL doesn't need to be disconnected when you have a spoiler. There is a brake sensor that you can swap out to bypass the 3rd brake light. If you look at your passenger side tail light, there shoud be a small box with a wire harness connected into it. If this box is black, you have the wrong one so you can go to a junkyard and grab a gray box outta an accord that had a spoiler. I'll try and post a picOriginally posted by puertorico45I have a 93 accord 10th anniversary and it had a wing on it with a brake light but it was disconnected. My friend came and disconnected my 3rd brake light and connected the light on my wing. Now on a gauge cluster it shows the brake lamp light always on. It could be that my friend connected it wrong or maybe a fuse????
*edit* Here you go.
"I'm a dude playing a dude, disguised as another dude"
"That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved."
Romans 10:9
><((((º>
What is the name of that brake box? My light started going on when all my bulbs are fine. I want to replace it but I have no Idea what the hell its called?? Oh I need the black one, I dont have a spoiler. I Want one!!Originally posted by bigjoegood1Yeah the center high mounted stop lamp or CHMSL doesn't need to be disconnected when you have a spoiler. There is a brake sensor that you can swap out to bypass the 3rd brake light. If you look at your passenger side tail light, there shoud be a small box with a wire harness connected into it. If this box is black, you have the wrong one so you can go to a junkyard and grab a gray box outta an accord that had a spoiler. I'll try and post a pic
*edit* Here you go.
Sorry for the thread jack.
puertorico45, let me know if any of the above works for you."I'm a dude playing a dude, disguised as another dude"
Romans 10:9
><((((º>
MAte you've probably done one of your relays inside the tail lights.... umm i had an aftermarket spoiler sitting on my car and it did something to my relays and the brake light in the cluster always shows up until recently i changed the relay to get rid of it....
check your relays....
Tommy Gun.... Gunning It all dA waY...
90 EX DUMPED!!!
