my car idles at a little over 2000 rpm so obviously my gas mileage is a bitch. what rpm do i adjust to?
High Idle
High Idle
My 1992 honda accord LX 5 spd.
"Behold! What was once thought to have been
buried beneath the sands of time,
the ill-fated Haynes Repair Manual has been resurrected
from the depths of a watery grave." - LX_Accordian
Tags: None
Well for cold idle, mine comes just sort of 1,900 in single digit days, though usually its about 1,700 in winter.
Stock tach matches my digital tach readings.
And also, check the sitckies.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
Had a rough idle/high idle problem and it turned out to be oil in the connector for the temp sensor for the ECU. The sensor is located just behind and below the dizzy and when the bearing went on it last year the oil was leaking out and worked it's way into the connector. Cleaned it out, sprayed some contact cleaner into it and it idles perfectly now.
warm idle = warm weather?
cold idle = cold weather?
i'm car-tardedMy 1992 honda accord LX 5 spd.
where is the idel skrew at i dont no mine is at like 400 and i want to turn it up a lil
93 EX COUPE, F22A6 turbo project
http://www.cb7tuner.com/vbb/showthre...45#post1615845
96 lexus sc300 DD
http://www.cb7tuner.com/vbb/showthread.php?t=143563
back from basic.... off to ait.... CB still being worked on i have mad plans for it .. sorry cant tell its on the hush hush for now but all i can say in somewhere around 500 hp soon to come..
curious.
i read the manual and it said u need to do a bunch of crap to adjust the idle. can i just turn the screw?My 1992 honda accord LX 5 spd.
