need speed sensor plug wiring help!!
    whats up.i am installing my speed sensor and have a cut plug for the sensor.my turbo h22a wagon has not been wired for speed sensor as of yet.the engine harness has the 3 wires from the harness ready to be spliced in for speed sensor plug but the wire colors are different and i don't know which goes to which. the plug that i hav connected to speed sensor has 2 white wires with blue stripes & 1 white wire with a red stripe.but the 3 wires from engine harness has 1 yellow wire-1brown wire-1black wire.does anybody know which wires connect to which? (2 white w/blue stripe -1 white w/red stripe)(1yellow/1brown/1black) any help will be appreciated since i have no speedometer or v tec engagement without speed sensor.
    http://www.cb7tuner.com/vbb/showthre...light=vss+wire
    they discuss the wires here...I'm still reading to see if it answers all your questions...but it's the only post I've been able to find that even talks about the wires.
    vss=vehicle speed sensor..juuust in case it wasn't clear
    from that post I gathered this:
    Originally posted by Torqstr
    The yellow VSS wire is + power when the ignition is turned to ON...
    The black VSS wire is - ground always...
    ...the blue wire becomes orange at the ECU...
    *edit...oh damn h22...ok I'll search in the h22 swap area for a wiring diagram...
    k not finding a diagram or color description...did find this in the swap faq
    Originally posted by jas_r34
    ·The vehicle speed sensor plug gets moved from the front to the back on the engine, near the O2 sensor plug. Same wires, different location to fit around the H22.
    ____
