speed senser
    speed senser
    i cant tell how fast im going i replced the senser i was wondering could the speedometer be broke and if so can a 91 cluster fit in a 92 i have 91 for parts is a 4 door 5 speed f22a1????
    [IMG]http://cdn0.youplusplus.com/bs/small.84960.jpg[/IMG short ram,wires.plugs,header
    sure if it's the same type as the one in your car
    Only Hard Thing is Keeping it Clean
    my ride
      I think those are similar enough...
      Have to make sure if yours is an auto the one you get is an auto...etc etc...
      ____
        1. It depends if its a Denso or an NS cluster. Those two clusters ARE NOT interchangeable.
        2. Verify the voltages coming out of the plug with some sort of volt meter with key on engine off.
        3. If wires test good it could be the cluster itself. If not you have a wiring issue not a gauge cluster issue.
          see...I knew I didn't know
          ____
            ok ill go ahead and try it but they both are 5speeds lx only diff 1 is a 2 door and the other is a 4 door
              Does your RPM meter "forgot name of the thing" not work as well? because my speedometer dosen't work as well. But the tachometer does "remembered said name" ?
