"Engine Restore"
    "Engine Restore"
    You folks like it or dislike it? Good or bad for our engines?
    ive used it and it actually raised my gas mileage. but i added it after i changed my oil and filter. but it ran smoother. i havent put it in my current motor yet tho i did a seafoam treatment on that. but ill be using the engine restore soon after it gets swapped to the 5spd tho. but i would recommend it tho
      never heard of it! what does it do exactly?
        is that the stuff in the can that looks like a soft drink?
        Never used it but ive used a lot of stuff like it and I think seafoam is the best and easiest. I use to use this other flush that I think is called just Flush that is sold at wal-mart and it actually worked out well... I think maybe gunk sells it. I put in a little a few days before I am going to change my oil and then I take out a quart of oil and put the rest in.... drive around on the free way for about 30 min (go around the 610 loop in Houston) and come and drain out the rest and the viscosity of the oil is like water.
        I dont know what kind of oil you use but I use 20W-50 with slick50. Though i swear the slick 50 is gumming things up or it puts some strange thick coating on all the metal.... hell maybe thats what its suppose t do?
        AD5OS
        FOLDING@home
          uh...wtf? your not in anyway supposed to put 20w-50 into your motor...why would you?
            Why would I put 20W-50 in? Cause I live in hot as hell TX driving stop and go traffic with 120+ degrees on the freeway and stop lights ever 100 yards or so.
            I dont wanna go off topic but maybe there should be a good what oil type is best for your weather topic if it hasnt been covered at naseum yet. actually I would just run straight 50 if I could find the stuff.... or maybe something synthetic that goes to 60 or 70... its thicker and offers better protection in high heat situations.
            anyway about flushes... my dad said he used straight kerosene.... aka aviation gas in the engine after draining most of the oil. for 5 minutes. said it would smoke like a MOFO... but that was on a 68 mustang... dont think I would try it on the newer engines like ours.
            AD5OS
            FOLDING@home
              I use 10w30 and it bears texas heat just fine...I dont see why you need such a thick oil. Im surprised that your engine hasnt had any issues. Honda oil clearances are usually pretty specific on what oil they use. Too thick and it doesnt get through.
                What's seafoam?
                What exactly is seafoam anyway?
                H22 Fund Cancelled. Flight training underway.
                  too thick? Nope. I dont wanna get into this debate... talking about oil in a car forum is like talking about politics... to many opinions and not enough facts!
                  AD5OS
                  FOLDING@home
                    its a kind of engine treatment that basically flushes out all the carbon built up inside the engine. It helps w/ injectors, cleans the intake plenum/manifold, frees sticky lifters/valves and decarbs the inside of the engine. Its pretty effective stuff.
                    member's ride thread
                    91 Accord SE 176k
                      thanks for the explanation! i've always wondered what it was but never bothered to research it. i may have to do this to my car soon. hopefully it's not too expensive.
                      Originally posted by deevergote.
                      And please, for the love of God, type like a human being!
                        would carbon built up change your compression?
                        lol ^_^
                        峠 で ドリフト を して 下さい。
                        steam linky facebook, y0 俺 は 走り屋 です。 clickable ^
                          lol ^_^
                          No has nothing to do with compression.
                          Yes its quite cheap. I always have a bottle of it around with me... its great as a cleaner as well.
                          Ive never put it in my gas tank but I'm sure it couldn't hurt. I think its better to put a lil in your pvc a lil bit at a time... I put a cap full in a minute slowly letting the pvc suck it up. I think you are suppose to put a good amount in the pvc then turn off the car and let it soak in then turn it back on.
                          AD5OS
                          FOLDING@home
                            yeah kinda right, you're supposed to put 1/3 of the can in your gas tank, 1/3 in your brake booster vacuum line going into the intake plenum, and 1/3 in your oil crankcase (right where your fill in oil, through the oil cap)
                            91 Accord SE 176k
                              Carbon build up can change your compression if there's enough.
                              I took a motor apart and it had a few mm of carbon build up on it. Less volume=higher compression.
                              It won't change it drastically, or even enough to where you'll be able to tell a difference. But it does technically change it.
