As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
engine running rough
    ok,so i go to start up my car and she kicks after about 2 seconds as usual.then when i rev it to warm it up it shakes the car and it seems like its missing and it sounds like a damn v8 the exhaust makes a burble burble sound(its usually very smooth and deep).so i cut it off and poped the hood.i saw nothing out of the ordinary.so i got my dad to take a look and listen to it.he says its a vacuum hose missing somewhere.what do you guys think it could be?
    heres a clip of how it sounds
    spoonsportsaddict
    First of all, if you want your engine to last don't "rev it to warm it up"
    Sounds like its not firing on all cylinders. check you sparkplug wires
    wat?
      thats not a video of when its cold.usually in the morning i rev to like 2k but never higher just to warm it up.do you really think it could be the spark plugs?those are pretty new.....
      spoonsportsaddict
        yeah definitely one of your sparkplug wires is not on the plug all the way, so therefore it sounds more like a subaru boxer engine.
          how would i go about fixing this?
          spoonsportsaddict
            Sounds to me like you have an exhaust leak or something.... Dont know whats with the white smoke but I would guess you have a cylinder thats burning oil or something(antifreeze)... lots of smoke going on there....
            AD5OS
            FOLDING@home
              1)Its not an exhaust leak
              2)Thats not alot of smoke at all.
              My car has alot more "smoke" and runs perfect.
              wat?
                yea thats not an exhaust leak.i just got my exhaust done.if its the spark plugs like all of you say,how do i fix it?do i need to buy new ones?or can i fix them?
                spoonsportsaddict
                  Its not firing on one cylinder start the car and let it idle, then disconnect one sparkplug wire at a time and if it make it run worse that means that one is working. If you unplug one and nothing happens, thats the one that isn't firing. The problem could be inside the dizzy the wire or the sparkplug.
                  wat?
                    yea.i just tried that and all it did was spark and then cut off
                    edit:hahaha i feel like such a noob now.nvm i found it.thanks for the advice
                    spoonsportsaddict
                      i made sure they were all in.sounds just as bad as before!HELPPP
                      spoonsportsaddict
