Man I been having problems with my car, I would drive it for a while then when i turned it off to run in a store it wouldnt crank right back up, it cranks and the car sputters then i crank it again and it doesnt do shit, eventually it would start but the other day i hopped in and started it right up went tothe corner store walked out the store and nothing, usually when i wait it starts right UP. my dist. is brand new and so are the spark plug wires,i pulled out hte spark plug wire and there is oil on the spark plug wires is that normal? could it be Sparkplugs/wires/dist/ SOMEONE HELP thanks.
Car Wont Start
Oil in SP is not normal. Replace the plugs and see if it goes away.
If it does go away , replace the SP tube seals ASAP.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
Oil in SP will cause misfiring. Usually it's just the plugs. How bad is it?Originally posted by Slice Onecould the oil fucked the SP and the wires or just the SP?Last edited by ExplodingCake; 03-30-2008, 02:10 PM.
bad enough to where if i pull outthe plug wire wipe off and put it back in its wet again, like there may be a puddle down there.im going to change the plugs and see if that works. but i was wondering if it could be a fuel problem, ill have to check the fuel filter too. sucks that little shit can make your car stoprunning completely lol._____________________________
91 Accord F22B
That's nothing compared to what happened to me.
Anyway , get new plugs but clean the tubes as clean as you can.
- Get the SP tube seals replaced
- Check fuel filter
- Check fuel pump pressure
- Check main relay
Im having the same problem today. Started up and ran fine yesterday. Today, go to start, it starts. I wait for it to settle at idle(800rpm), it bogged down, revved up, bogged and finally died. I pushed it across the street and it starts but it wont hold. Plugs/wires are fine, fuel pump has about 20k on it, so ima check the fuel filter.
Keep us posted.
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
Slice One, sounds like typical main relay failure. Check this. Get into the car and put the key in the on position, dont crank it, ON position. All your dash lights come on right, keep an eye on your check engine light. When it turns off, listen for a click. If you hear no click its the main relay.
If the main relay checks out, pull the cap and check your igniter. Igniters always go out on these. If its an OKI brand igniter its bad. Let me know what you get from there
