Alright, so once again, I am going the h23 head swap (slowly...)
I have run into a handful of problems so far, but this is my worst problem.
The nut for the timing belt tensioner is stripped to shit. I have used almost every tool I can think of to try and remove this piece. I need to remove so I can
A) get to the last bolt holding on my water pump
B) Loosen the tension so I can get the new timing belt on there.
I am truly out of ideas to get this nut off. It is almost a perfect circle. The only other alternative is to torch it, but I don't access to that.
Any ideas? The timing belt and balance belt look brand new, so if worst comes to worst I don't have to replace the water pump (putting my faith in the fact that whoever did the last timing belt job, actually replaced the water pump... and then continued to strip the shit out of the nut)
I have both the h23 belt (fits over the tensioner and such, but has too much slack) and the gsr belt (wayyy too tight).
