So I blew my motor yesterday with a little less than 190,000 miles on the clock. I recently swapped my automatic for a manual (got it done about 2 weeks ago) and on my 1st highway run, at about 90mph, rod #3 broke (one side of the rod cap broke away from the rod). And at this point, it seems as though the bolt did not break... its still attached to the cap, which looks like an 'S' now, instead a 'U'. This allowed the rod to become disconnected from the crankshaft, which in turn pushed the rod through the block. I'll post more pictures once I disassemble the block.
I've got a spare block I was saving for sleeving, extra rods, pistons and a crankshaft. But I don't want to just swap in a stock F22.
I'm trying to figure out if I should just use my spare F22 block and get forged internals, or go the H route. I've found a quite a few low-priced H22's and even some VTEC H23's, but I don't know what would really be better to do.
So I guess my question is, what do YOU think I should do? Stock H22, 23, or built F22?
I'm personally leaning towards a built F22, 1) Because it would be like having a new motor, but stronger, and 2) I don't hear many good things about the H-series FRM sleeves. Though, starting out with 200HP would be great...
