steering is weird.
    steering is weird.
    I was driving my car right now and as I turned I noticed a squeaky sound coming from the steering wheel./
    any ideas of what it might be?? I'd really appreciate it.
    are you sure it wasnt a loose belt?
      power steering belt...needs to be tightend
      wait....idk if a steering wheel makes a noise.
      But your power steering belts do!
      *Needs*
      -New shocks
      -Struts
      -Drop
      -Cleaning
      -New Tires/Wheels
      -New Window Tint
      -Alot more lovin'
        either the belt, low p/s fluid, or a bushing or plastic piece that surrounds the steering column could be causing that.
        Without hearing it myself I can only suggest checking those.
        fixes are...tighten/change the belt, fill fluid (check for leaks), lube bushing/plastic piece
        On that last one...just a generalized possibility...spitting ideas out there is all.
        ____
          yea use some lucas power steering fluid(psf) for a lil bit if the belt is tightened enough. mine was doing the same thing until i used that stuff. if not your pump may be going bad and from what ive heard sometimes the rack and pinion may be going if the steering gets harder or tighter. good luck!
          no
          Accord turbo kit under $2k here
          $30 HID kits here Thread
          "What a selfish bitch. She looks like one too. A smart-mouthed, facebook-ing, "i dont know if im straight, bi or *** yet" little brat." -greencb7inkc
          "No Herra Frush, Slammed, tucked or frame dragging here. I'll leave that to the mini trucks...." -fishdonotbounce
            well it didn't sound like any belts. I looked at all the belts and they're all tight but it sounded like it was more from the steering wheel itself.
            thank you guys for all the suggestions
            I'll take a closer look to see if it's a bushing or fluid or somthing
            again thanks.
