Sport tranny
    Sport tranny
    I just recently bought a auto accord and im new to the sport tranny. wat exactly is a sport tranny? and why is the green S light on all the time? also the tranny only shifts into 1st and 2nd only after getting REALLY REALLY warmed up itll decide to shift into 3rd and 4th, way caused this? A guy that i work with says it could be my tranny filter? any ideas
    have bought from ::
    Frazzums, Ilikebigbutts
    have sold to ::
    The Sport function is absolutely worthless. It causes your transmission to shift at higher RPM than normal at partial throttle. At full throttle, the shift points are the same.
    The S light shows that the Sport function is activated. It also may be indicating an error code. Have that checked out. Your shifting issue may be related to the TCU. OR... it may be a failing transmission.
    I'm not an automatic expert... I've owned 2 CB7s, and both were manual.
      thanx deevergote yea my last cb7 was a manual ex i miss it now i got this lx but hopefully i wont have to worry bout it to long thinking bout doin a auto to manual swap heard its kinda hard
      have bought from ::
      have sold to ::
        Our accord don't have tranny filters, my advice is to change the fluid a few time about 3 time in a month or so. If your S light is on it may be throwing a code, I would recommend finding that out.
        Does the car jerk when it goes into gears or does it sometimes bog down?
        Click Me
          i went to discount auto parts and asked how much a tranny filter was and the gave me a price for it i seen they had two diff kind and no it doesnt jerk or bog BUT wen i do take off it sounds like it wants to stall out till hit the gas more but it was also header out so not sure if that caused it to act like that on take off
          have bought from ::
          have sold to ::
            have bought from ::
            have sold to ::
              If there is a filter in it it may be internal and therefore not serviceable without a shit load of work. Also I just took a look in the owners manual and I didn't see anywhere where they mention transmission filter.
              Click Me
                are you serious? i paid jiffy lube $110 to change my tranny fluid and they said that would need to change the filter as well!! wtf
                  Call Honda and ask for the Part Number, or go down to Jiffy lube and have them show you where the filter is. I am 99 % sure there is not filter unless its internal and if it is 110 is cheap.
                  Click Me
                    I suggest you click this link and read. This will help you fix the problem.
                    A/T: Pulling the TCU Code
                    1996 Honda Civic LX 2009-2012
                    2012 Kia Optima LX 2012-2013
                      it could be you tcu. my buddy had the same problem and we just swapped his tcu out and it took care of his problem. unless one of the seleniods on the tans went bad.
                      92ex coupe h22
                      93 240sx with silvia front end (kadet in the works)
                      http://www.cb7tuner.com/vbb/showthre...=1#post1894990
                        hey thanx man if it wasnt dark right now i would try it out lol
                        so ill try it wen i get off of work tomorrow thnx again DarkShadow
                        have bought from ::
                        have sold to ::
                          ^^^ OK so i tried this and didnt see the sport light blink at all BUT i did see the C.E.L. blink. 4 long blinks and then 1 short blink. Im not really familiar with all the codes and blinks can someone help out thnx
                          have bought from ::
                          have sold to ::
                            code 41 will tell more later
                            Click Me
                              thnx and that would help me alot to if you would
                              have bought from ::
                              have sold to ::
