hi everyone i have an h22a4 complete motor tranny everything and i need help conveting the motor to obd1 cause i dont kno any other way to do it
h22
You have 9 posts... so I'll let this slide. Saying this will get you banned under normal circumstances.Originally posted by jewinaboxSearch.
Additionally, unless one of those 9 posts happens to be a DIY on the OBD2-OBD1 conversion, you have NO right to tell someone to search. I'll remember that when YOU need help.
You'll want to get the OBD1 distributor and OBD1 injectors. As said above, a conversion kit will make the wiring much easier.
I'm planning on doing an OBD0 to OBD1 conversion this summer... yeah... THAT will be fun...
Deev, I believe the above kits are for converting OBDII *CARS* to OBD1, not motors. I keep seeing people saying to use these to convert your motor, which is not correct. They are there to use an OBD1 ECU in and OBDII car.Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
There are kits to convert an OBD2 motor to be run in an OBD1 car (mainly used when the B18C5 became a popular swap in the EGs)
I don't know for certain which kits are being referred to above, so perhaps it was hasty to say that those suggestions are correct...
Actually, with the OBD1 electronics, you shouldn't need a harness.
To the OP, it's a shame you already have the H22A4... I'd have suggested against buying it if you had mentioned it beforehand! I'm guessing you came across a good deal on it?
