found the problem!!!!
    Ok, i recently posted a thread about some steering issues, and a shaking problem....well i found out that what i believe to be the motor mounts were all wasted, causing the engine to drop. I havent been using the car since i got down here with the exception of the test drive i gave when i got it here. So my question is, do the motor mounts have to be replaced, or is the rubber piece inside is what is supposed to be replaced. How much are the motor mounts? Is it an easy job? here is a pic of the front one.
    here is a zoom in
    Hey mine steering is a little Diffirent than my old Cb7's
    how do you know if ur motomounts are bad?????
    Ride: 2002 Lexus IS300
      [QUOTE=kemacoco]Ok, i recently posted a thread about some steering issues, and a shaking problem....well i found out that what i believe to be the motor mounts were all wasted, causing the engine to drop. I havent been using the car since i got down here with the exception of the test drive i gave when i got it here. So my question is, do the motor mounts have to be replaced, or is the rubber piece inside is what is supposed to be replaced. How much are the motor mounts? Is it an easy job? here is a pic of the front one.
      You have to replace the whole mount. You can usually find them in junkyards, if you don't want to buy a whole new one.
      The other option is to fill the ones you have using $15 worth of home depot stuff. There is a DIY for it around here someplace. This usually adds a little bit of vibration, because you loose some of the dampening effects, but you gain some launching stability.
      I don't know that bad mounts would affect your steering, though.
      1992 Prelude S w/swapped H22A
        for the front mount, Energy Suspension makes a polyurethane insert that just goes over the broken mount and corrects it, so there's no need to buy a new mount for that one. I think the kit I got was $25 shipped off of Ebay, just search in ebay motors and it should come up. It's WAY cheaper than buying a new one for like $70, plus it's better and will never wear out.
        For the other mounts, ESPnet on here makes some polyurethane ones as well, custom tailored for the CB7's engine or the H22 engine if you want to swap soon. I think it runs like $235 for all, either 3 or 4 idk, but they're good quality parts. Just for Honda mounts alone, you'd spend at least that much if not more and they're not made of polyurethane so they'll eventually fail again. The ESP ones wont.
        And another big factor if you're going the OEM Honda route is if you have a rear hydrolic mount. Those run 200+ just for that one mount so it's pretty costly. But I do believe you can swap that one out for a regular mount somehow. So check up on that.
