My accord is showing 3 engine codes, one is for the oxygen sensor, the other two are a code 15 Ignition output signal and a code 43 Fuel supply system.
Its a 90 Ex coupe with an F22A4 swap. I havent checked if the stock ecu is in the car, but most likely hasnt been touched.
What would cause the code 15 and 43? The only problems with the car is the fuel gauge not working correctly. The engine and auto trans were swapped with stock replacements before I bought the car. Any specific things someone can think of to check would be great.
