Battery Relocation
    Battery Relocation
    So I want to relocate my battery in the trunk to free up some space and make my engine bay look cleaner. I know I can get the kit from summit for 70, but has anyone out there actually done this mod?? Hints??? Thanks
    yes... Buy the kit or make it yourself. Fuse both ends of the power wire.. Not much to it.
      so what guage wire and what rating on that fuse would you recommend? i see those "marine" battery boxes at wally world for pretty cheap and wouldn't mind doing this myself to free up some room in my engine bay.
        You still need a sealed battery with the marine boxes, the box is not sealed and has no vent. You can run a regular battery if properly vented in a proper enclosure . I have two 4 ga runs but you can definitely get away with one.
          yeah i was thinking of upgrading to an Optima and getting away from this ugly autozone battery.
            So if I were to get an Optima battery, throw it in my trunk, would that work? as far as needing ventilation. I've smelled a bad battery, holy shit that stinks! And would regular 4 gauge amplifier power wire work?
              Yeah 4gauge amp wire works, that's what I have in my car. I have a Marine batt. box for a groupe 24 batt. I have a 100amp fuse at the batt and the 80amp fuse in the fuse box under the hood were the power wire is ran. make sure you put a good body ground in the trunk and under the hood. I'm also using an Autozone batt. in the batt box and it's fine.
              Honda-mans best friend!
              who said it was a dog?
              PINOY PRIDE
              OHIO CB7's
