A/C in H22 swap
    A/C in H22 swap
    Alright, so I'm doing an H22 swap on my 92 and I've been told that that its too expensive to convert the a/c from a 92 accord and make it work in an H22. Is that just b/s or what? I always thought I just put my pump on the H22 and I'm bueno. smack me if I'm wrong
    Not wrong, but I don't think completely right, either.
    I think you have to swap the compressor pulley, assuming you are going with the H22's crank pulley (and alt). If you use your F22A crank pulley, then you are golden (you also have to use the F22A Alt).
    FYI, most questions like that are covered in the Swap FAQ, and if you check that first you might get an answer faster, rather than waiting for someone to answer you.
    1992 Prelude S w/swapped H22A
      I had to swap the h22 crank pulley and alternator for the f22's. the h22's a 5 spline and the f22's a 4 spline.
        Or you could just run the smaller belt... if you have 4 and 5 rib pulleys, just run a 4 rib belt. It'll turn the 5 rib pulley just as well. Tension it properly and it shouldn't skip. This isn't the cleanest way to do it, but I know many who have.
          yea just run the accord compressor and braket. and 4rib belt
          Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
          But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
            This is what I did and it works beautifully. A/C is nice and cold!
            Originally posted by Junior Smurff
            Nevermind guys, google search works wonders!
            I don't have road rage, my car just goes faster than yours!
            Accords are for winners. And Grandmothers. But mostly winners.
            I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
