Well I got everything cut out and all the wires ran through but they wont turn on. The light on the switch does turn on but no lights. I keep blowing the in line 15A fuse?!?! Any suggestions?
Depo foglight install
Originally posted by 92CB7guyWell I got everything cut out and all the wires ran through but they wont turn on. The light on the switch does turn on but no lights. I keep blowing the in line 15A fuse?!?! Any suggestions?1992 Prelude S w/swapped H22A
I checked all wires, I have the depo kit so everything is loomed. I keep blowing that 15A fuse, like I said before the switch lights up and all. Everything seems grounded because it doesnt make that obnoxious rapid clicking noise just one click but the fuse blows. Should I connect it to the battery or the positive fuse box, or negative. I dunno its somewhere before the relay.
did you connet the red to the battery on the fuse box.
or the plug into the 3 plug on the fuse box inside??Last edited by smokeeey420; 04-21-2008, 10:01 PM.
where are you pulling the positive from?
When I did mine a few days ago, I have one line connected to the positive on the battery then ran the line threw the bumper and grounded them to the ground for the horn and then the line goes inside and I saw this golden like bolt backed it out and I put a ground there and then lastly one to the fuse box on the inside. If I had my accord right now I would take pictures, but its in the shop and I don't know when I will get it back.
I have one red wire going to the positive on the engine bay fuse box, then the fogs are hooked up then the ground for them then the switch is grounded and i have the little brown connector to i think number 3 on the inside fuse box(is that the right one) Thank you all for the quick responses and the help.
Originally posted by 92CB7guyI have one red wire going to the positive on the engine bay fuse box, then the fogs are hooked up then the ground for them then the switch is grounded and i have the little brown connector to i think number 3 on the inside fuse box(is that the right one) Thank you all for the quick responses and the help.
So I called my local Honda service dept. and they said that I am running too much power through the fuse. I realized that but why, I have nothing custom in this setup its the entire Depo kit brand new. I am really confused my indicator light comes on and the relay makes the clicking noise but the 15A fuse blows every time. Honda said to try a 20A with the possibility of it all starting on fire or blowing everything, yeah screw that! Cpmike any ideas I know you are an expert on this.
