i just got a new tranny, my mechanic dropped the engine and found that the rear mount needs to be replaced. But when i called advance they asked me if it had a solenoid or not. Im not sure. What should either one look like?
Motor Mounts ????
Since you have the Automatic you do need the one with the Solenoid. If you run the one with out the Solenoid that meant for the Manual you will notice vibrations when idling. "First hand experience". = P
Originally posted by puertorico45i just got a new tranny, my mechanic dropped the engine and found that the rear mount needs to be replaced. But when i called advance they asked me if it had a solenoid or not. Im not sure. What should either one look like?
wait mine vibrates when i idle does that mean i need new motor mounts???? especially when i put it in gear or in reverse tryin to back out of my drive wayOriginally posted by Accord Euro RSince you have the Automatic you do need the one with the Solenoid. If you run the one with out the Solenoid that meant for the Manual you will notice vibrations when idling. "First hand experience". = P~CB7 Phoenix~
(picture missing help me get a new one
The California White Tux
*and its alive!! hahaha*
*under construction*M.R.T: http://www.cb7tuner.com/vbb/showthre...=1#post1689652 *changes soon to take over*
