whats a p14 out of and will it make a difference in my f22a4
p14
It already has been proven that even a chipped ECU (p06, p28, whatever) for a STOCK F22ax motor done by tuners on this forum, they so no benefits worth mentioning and agreed that the stock ECU does a good job. I believe this even holds true for stock motors with I/H/E (intake/header/exhaust) setups.
When you modify the motor outside of what I mentioned above, with parts that actually improve performance (not fuel psi regulators, AEM fuel rails, etc), I'm talking cams, ported head, etc....then you will gain from a chipped ECU.
So based on the 1st paragraph alone, why bother? I bet there is more to be gained from lost power due to improper maintenance of the motor or previous damage to the motor's health than trying to swap another Honda ECU.
This issue has been discussed previously, again more research on your part needs to be done.
Originally posted by HondaFan81It already has been proven that even a chipped ECU (p06, p28, whatever) for a STOCK F22ax motor done by tuners on this forum, they so no benefits worth mentioning and agreed that the stock ECU does a good job. I believe this even holds true for stock motors with I/H/E (intake/header/exhaust) setups.
One exception that I think should be mentioned is the P12, which is out of the 92-96 Prelude S, which came with a F22A1. It might give you gains if you had an F22A1 or F22A4. It is still a stock ECU for a F22A engine, though. This has been discussed many times, do a search for P121992 Prelude S w/swapped H22A
