I have a CB9 w/ Jdm H22. I went to the Newengland dragway last night w. 18in w/ Toyo 4. I didnt have time to put on mine 15 w/ 205/50/15 Toyo Proxes 4. Its the first time I ever raced at a drag strip. My best time was a 16.2, I know I could do better than that, maybe 15.5. Wat rpms should I leave at. I have stock suspension.
Launching
I would say don't launch. Unless you have lsd is just makes your time slower spinning your tire all they way down the track. Just ride the clutch a little off the line. also since you have stock suspension wheel hop is probably your worst enemy right now. Try to stiffen things up a bit.-1991 Honda Accord LX H22a-
I had some bad hopping last night. I just wanted to get a base time before I started do some other work done. All I have is the stock trans, headers, 25.exhaust,MSD Cap, rotor,SS Blaster coil and no weight reduction. I was going to ride the clutch more next time I go,I was poping it. Thanks for the info. Will i get a better time w/ the 205-50-15 its a motigei racing rim and its alot lighter.NEW PSN
H22wagon
New project. 95 EG HB H22
RIP
3200-3800 rpms is a good start. i launch at 3400-3500 on the street, so i would figure a little lower than that to account for the more grippy race prepped surface. but wheel hop is definitely your worst enemy. i would rather spin through 3rd than get wheel hop. if you're on stock axles, wheel hop could break them if you hop it hard enough. dragging the clutch can only mask the problem so much.
Thanks for the info, I was worried about the CV Joints being stock. I'm going maybe next wendsday. I will update next week.
My best times were
RT .688
60' 2.602
330 7.027
1/8 10.591
mph 67.18
1000 13.690
1/4 16.294
I was to concered about my RT, and was concentrated on my launch. I'm learning from my misatakes.NEW PSN
H22wagon
RIP
Your 60 foot is crappy. It seems like you were having traction issues. Cut that down you can run a lower time. What transmission are you running that makes a difference. How you launch the car makes a difference and I dont mean just a certain rpm how you use the clutch is important. Feathering the clutch helps. I launch my car at 3800-4000.
