ac....help
    ac....help
    ok last year i charged my ac it worked for like 3 days and that wuz it i went with the r1-34a stuff.... then i did the dye in the lines never found the leak any where does anyone have any clue where its going?> could it be a bad compresser that would do that or under the glove box where the blower and stuff is, i even tryed that stop leak shit it never worked..lol
    if your loosing freon the you have to have a leak... 3 days and its gone... thats a mayjor leakyou might have to take it to an actaull AC shop that have detectors to find the leak... then repair it yourself.... i use to work in an AC shop and where the hard lines connect to the lines that go to the firewall lines that go to the evap box under the dash are bad about leaking.... also check you lines around the dryer bottle under the crusie cntl unit...or the leak could be the condensor on the front side of the radiator... could be alot of things so check everything....
    Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
    But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
      one time it leaked out with in 1 day...lol and i need to know how to take apart the plastic peace under the glove box to see if its leaking there
