Bezel removal
    Bezel removal
    I am tryng to remove the bezel on my 92 accord, ive removed all the screws from it, but the bezel seems to be stuck, i try pulling it out but it doesnt want to come out, are there maybe more hidden screws?
    there are some screws down under the ashtray and cig lighter did you get them? some behind coin tray, vents, cruise and sunroof switch, i think the dimmer, maybe even behind the radio
    ive had mine off 2 times and cant remember but there is alot of screws
    smoke tires, not drugs.
      so is there screws behind all vents?
        Does anybody know of a diagram that i can look at?
          go here
          "Real intelligence is like a river; the deeper it is, the less noise it makes.”
          Click Me
            ^^That's a great link. Is it absolutely necessary to remove the console to remove the bezel? I need to get access to the heater controls, but really don't want to remove the console if I don't have to. If the console has to be removed, do the underdash kick panels have to be removed too?
            I removed the console on my Integra a while back and had to take the kick panels off to access a few of the screws that held the console in. On top of that, i had to remove the glovebox to get at a few screws holding the kick panel on the passenger side. Such a PITA. I'd like to avoid all that if I can.
            http://www.g2ic.com / http://www.beyond.ca / http://www.accordwagonclub.com/
              Nah, you don't need to remove the centre console...
              If you can remove the screws behind and under the radio, you should be fine.
              HONDAMENTALISM
                so i installed a new bezel, 1 problem tho, i got it off a 91.....
                cb is a 92..
                  Its basically the same. The only difference is that rubber trim that goes over the steering column. 90-91 is a wider piece than the 92-93...
                  Sig removed due to excessive size
                    1 problem tho, now i cannot install the top cover that goes between the bezel and the wheel, the 92 bezel has a groove to it, the 91 is flat across
                      Im not sure about that. I thought that it is only that rubber trim is different. You can try taking out that rubber trim and see if it is going to fit...
                        just use a drill or something and make your own groove
                        Meh, not feeling the honda game anymore.
                        MY CAR IS SOLD!!!
                          i was thinking of making my own cut, but i dont think that would look too well i might just go find one at the junk yard, and sell this 1 to some1 with a 90-91 cb
                            Got the bezel off and all. Went straight for the heater controls only to find out the connection for the heater cable was fine.
                            Turns out the cable slipped off at the other end under the glove box. Thanks for the info in here though, much appreciated.
