What is the purpose of the balancer shaft??
Balancer Shafts
The balance shafts (there are two of them in F22A's) are meant to do exactly what they sound like they do... balance.
Essentially, even with all of the meticulous balancing Honda engines go through, they still cause a whole lot of vibration. The balance shaft's purpose is to eliminate this excessive vibration, counter acting it by force using unevenly machined shafts that extend 3/4 of the way through the block and spin at a speed equal to the crankshaft. There timing is spaced so when the crankshaft 'throws' most of its mass in one direction, the balance shaft should counter-act its force, lessening the harmonic vibration that occurs.
Running without these you will gain a small amount of power since your engine will have less parasitic drag but, your engine will idle much rougher, and engine longevity may come into question also. I personally have never run an engine with a balance-shaft eliminator kit.
