As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
Check engine light Code 15
    We checked the CEL it is a Code 15
    which is Ignition Output Signal..
    WTF is that?
    is that the reason why the car will turn off and won't start for another 10 to 15 minutes?
    what needs to be changed so i can tell the people that are working on my
    car to fix it
    Ignition Coil.
    Originally posted by DarkShadow707
    CODE 15 – Ignition Output Signal.
    Ignition Output Signal – provides control of ignition timing by determining the optimum timing using a microchip in response to engine speed , throttle position , coolant temperature and vacuum pressure.
    CAUTION: When replacing components on the ignition , it is HIGHLY RECOMMENDED that you disconnect the negative battery terminal.
    What to do: Please note that 90-91 Models have an internal ignition coil while 92-93 Models have an external ignition coil. It is recommended to acquire an ignition tester. On this process, spark plug wires should be tested to determine the problem. Pull out one spark plug wire one at a time and connect the tester. If there is enough power to the wires , sparks will be visible to the electrode. If this process bring great success proceed on testing the ignition coil and igniter. Otherwise replace the spark plug wires.
    In order to test the ignition coil for 90-91 models , remove the distributor cover and rotor. Using an ohmmeter touch the electrical probes of terminal A & B of the ignition coil. It should read 0.6 to 0.8 ohms. If your readings are nowhere these specifications , replace the ignition coil. To replace the ignition coil , remove the screws form the primary terminal and the screws from the coil and slide the coil out. Installation is reverse of removal.
    In order to test the ignition coil for 92-93 models , disconnect the electrical connector from the ignition coil tower. Using an ohmmeter touch the electrical probes of terminal A & B of the ignition coil. It should read 0.6 to 0.8 ohms. If your readings are nowhere these specifications , replace the ignition coil. To replace the ignition coil unplug the primary electrical connector and remove the ignition coil wire. Remove the two bolts that are located on the mounting bracket and remove the coil. Installation is reverse of removal.
    It is also recommended to reset the ECU.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      you got a priice range on how much cost?
        Approx $100. I suggest get that tested first.
          how can i test it?
            Refer to my quote above.
              it ranges differently..
              search around a junkyard first and get a price from them...then ask the dealer on what they charge. Rather than being on the spot and paying without knowing what you coulda saved.
              *Needs*
              -New shocks
              -Struts
              -Drop
              -Cleaning
              -New Tires/Wheels
              -New Window Tint
              -Alot more lovin'
                I'm having the same issue on my 92 exr...... I've replaced the main relay and the coil behind the dizzy. My plans r to get a dizzy from the wreckers 2morrow morning. unless some1 has a better plan ?????
                Just Purchased My First CB7!!!
                  new/used dizzy from wreckers solved the issue!!
