HELP! fuel problem? maybe?
    I got a little problem, i think it is something to do with a fuel issue? whats happening is while im driving the revs will be fine but as i slow down to stop at the lights and chuck the clutch in the motor stalls or drops down really low (like 100-200 rpm) then recovers, also when i go to rev the car it sorta chokes then catches on? has anyone had this problem before? and how do i fix it? thanks
    how much gas do you have in the car at the time it does this?
    I'm having a similiar issue and I'm beginning to think fuel filter is the problem..
    90 accord EX automatic F22A4 232,500
    DIY ram intake
    0gauge/4gauge BIG 3
    stock alt rewound to 120amps
    optima orange top 830cca 1030ca
    fully synthetic valvoline "Max Life" 5w30
    Other rides:
    2004 Jeep Liberty v6
    2001 Honda civic ex coupe 1.7 vtec
      i am also fighting this problem. i really dont think its the fuel filter, check your MAP sensor. also pull some codes, and if you dont know how to just search for it.
        it happens anytime? when the tanks at any level, but the thing is the car will stall but start first go? so im really confused at the moment!
          check your grounds, wires, plugs, dist, and just replace the fuel filter just because, its part of scheduled maint. anyway and it cant hurt. i would just go down the line. your cat could be cloged as well people come in my shop all the time because of simialar issues and there cat is either hollow or cloged. hope you get it figured out. good luck. also due a fuel injection service if you do a tune up or change the fuel filter.
          Hey yo uhhhhhh fry man!!!!
