I have a AEM dry flow filter ad was wondering how to make it fit on my stock pipe, the filter opening and pipe opening are the same size. thanks
Dry Flow filter on stock pipe?
You might need an adapter to fit it on the stock pipe. A lot of people take the soup cans and just jam it in the stock pipe then throw the filter on the stock piping. It works but I forgot the diameter.
I need to do this to my car for MPG sake.
What did u ask for at autozone ? What kinda intake/part number?90 accord EX automatic F22A4 232,500
DIY ram intake
0gauge/4gauge BIG 3
stock alt rewound to 120amps
optima orange top 830cca 1030ca
fully synthetic valvoline "Max Life" 5w30
Other rides:
2004 Jeep Liberty v6
2001 Honda civic ex coupe 1.7 vtec
CB7kid, go and get yourself a cone air filter, AEM, K&N, whatever you want. Take off your airbox, which has your stock air filter in it, and you'll be left with the pipe(hose) made of black plastic leading to your intake manifold. get another pipe 3 inches diameter and slide the mouth of the filter onto it and clamp, and slide the other end of the pipe into your stock intake hose and clamp. thats it. good luck!
Airflow mods often DECREASE mpg. The ECU sees more air, and dumps more fuel to compensate.Originally posted by 90HaccordI need to do this to my car for MPG sake.
My GTP was the other way around... but from all my experience with the CB7, and the experience of most of my friends, mpg goes down when you add such things, unless you retune the ECU.
As for sleepygreen's tb... he has the ultra rare JDM 4th generation Accord Type R throttle body... It gives an extra 25hp. That, or he just painted it to match his valve cover.
Clever. I've never seen a painted throttle body on a CB7.
Depends unless you have a "smart" ecu which a lot of newer cars have. Ours not so much.
thx bro.. im going to autozone maybe today if i have time and get myself a cone filter.. heheOriginally posted by AldoescuCB7kid, go and get yourself a cone air filter, AEM, K&N, whatever you want. Take off your airbox, which has your stock air filter in it, and you'll be left with the pipe(hose) made of black plastic leading to your intake manifold. get another pipe 3 inches diameter and slide the mouth of the filter onto it and clamp, and slide the other end of the pipe into your stock intake hose and clamp. thats it. good luck!
