Ok so I am looking at a local guy selling a full f22b swap. He includes a 5spd tranny and p51 ecu. I am keeping my 4spd auto so I need to know what ecu I need. Please help.
F22b help
Originally posted by Corban DallasOk so I am looking at a local guy selling a full f22b swap. He includes a 5spd tranny and p51 ecu. I am keeping my 4spd auto so I need to know what ecu I need. Please help.
Do you mean a JDM DOHC F22B, USDM SOHC VTEC F22B1, or USDM SOHC F22B2?
The DOHC F22B uses a P39 ECU, the SOHC VTEC F22B1 uses a P0A (it's a zero), and the SOHC F22B2 uses a P0B.
So, either way you go I'm thinking you are going to end up with the wrong ECU if you take the P51. Does that answer your question?1992 Prelude S w/swapped H22A
Ebay, engine importers, stuff like that are good places to look. You can also use a P14, which is for a USDM Prelude SI (had a H23A for an engine), but you would have to wire in a knock sensor. The P39 can be hard to find.Originally posted by Corban DallasWhere is a good place to get a p39? How do you like that motor? What mods have you done?
haven't done anything to the motor, and it pulls quite nicely. Definitely not an H22A, though.1992 Prelude S w/swapped H22A
So to add the knock sensor do I just need to pin the ecu and run the wire or what?Last edited by Corban Dallas; 05-21-2008, 07:26 PM.
