cooling problem
    cooling problem
    When I had my 2 door, i had a cooling fan problem where it wouldnt come on when the car got hot, but sometimes it would come on after i shut the car off and it was no longer need so i hard wired it 2 the battery everytime I needed it, I bought a new fan relay, and still it didnt work, I now have a 4 door and i swapped the motor from the 2 door into it, and i have the same problem, so now i know its soomething defective on the engine because the problem followed me from one car to the next, i just wanted your guys input as to what it could be...... its a f22B2
    not too sure myself, but just to throw a suggestion out there, you can try checking the temperature sensor?
      is it a fan temp. switch? or sensor? that determines when the fans come on and for how long. If its broken, then they'd just stay on all the time.
        have you checked the waterpump...if the water pump vanes have broken off, then there is no way the water will circulate; thus the hot water will not trigger the upper fan switch.
        Check if the upper coolant tube is cold, is so, then you need to get a new water pump.
        DEVOTE
        FS: Lokuputha's Stuff
          nope, its very much hot
            Could the fan timer play a part in this in any way?
            "I'm a dude playing a dude, disguised as another dude"
            "That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved."
            Romans 10:9
            ><((((º>
              i had a similiar problem. i replaced the fan switch and the engine coolant temp sensor and the problem went away.
                cant your coolant temp sensor cause you to have a silly idle too??
                  my car didn't.
                    Originally posted by Kamikaze_ITR
                    my car didn't.
                    i hope it does, because that is another issue i have, i hope replacing this will fix both
                      i might be a vacuum line.
