Belt slipping?
    Belt slipping?
    Hey guys I have a stock 92 accord with the f22. after i leave my car off over night or more than 10 hours or so and i start the car up, sometimes it doesnt start on the first turn of the key, like it never turns over. secondly, when it does turn over i hear the squeal as if a belt is spinning and does it for like 2 seconds and stops. what could it be? thanks.
    My Cb7 --->http://www.cb7tuner.com/vbb/showthread.php?t=112581
    belts are too loose
      Have your starter checked and your belts check for any damage or wear. If there is no possible wear on the belts , they need some tightening.
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        thanks guys. so which belt could it be most likely?
          Alternator belt.
            Alternator belt probably. My belt would "squeal" after a while of the car bieng off for a while.
            EDIT: Damn it DarkShadow beat me to it.
            3 CB's gone....
            1 WK Overland....
            Still miss the CB though......maybe one day.
              kk really appreciate the help guys.
                yeah man just to agree with the guys here it sounds like a belt slip due to them being too loose. Mine did that as well when it was really cold out and the rubber material would shrink and then when the belts heated up and the material expanded it went away. Good luck!!
                  i had squeeling problem similar to yours, tightened the brand new belts, still squeeled at start up, and with any load(high beams, a/c, loud radio, etc) tried loosening the belts, I thought it could be bearings in alternator or something, well, it ended up being the harmonic balancer in the crankshaft pulley, when i took off the pulley to change it, it came off in 2 peices!!!!
