aight so...first of all the only window that actually works right in my cb7 is the passenger side rear window and the sunroof if you count that as a window. the rear driver's side window rolls down ok but when i go to roll it back up it screeches horribly...it sounds like someone's keying my car. the passenger side front window rolls down really slow and i can't figure out what it is...(now for the real problem)...the driver side front window rolls down perfectly...it's rolling it up that gives me the problems. when i go to roll it up it goes like an inch then i hear a 'click'...i keep rolling it up and some how it has popped out of track on the front end of the window...i know it wasn't the 'click' because i've taken the door panel off b4 and watched it...also i have recently put a new regulator and motor in it. that improved it a little bit but it sill wont work right...and when i do get it back in track i keep rolling it back up and when it get's to the top there is a gap that is about an inch...it's really starting to piss me off
any body know what's going on??
