Any thoughts on how..........
    I'm curious how a 99' plus dohc vtec h23a would preform in a cb7 with the stock f22a6 5 speed. Is that tranny really going to hinder the performance alot?, or will the newer h23a have enough torque to deal with the stiff gearing? I was going to do the jdm h22a w/ tranny swap, but i can by a nice clutch and dohc vtec h23a for less.......... whats your thoughts guys?
    http://www.cb7tuner.com/vbb/showthread.php?t=143599
    I believe that motor on revs to 7. Correct me if wrong. So it will be better with that tranny. With h23 or h22 tranny you will be tached up high that 3500 doing 75 on the highway. Only problem is you will fall out of vtec when you shift because of the long gears.
    -1991 Honda Accord LX H22a-
      I did a little research on this swap again and found its similar to a h22 obd II swap, anyone know what type of ecu I should run on this thing since these motors all came from auto's? .....Im assuming any prelude h23 headers would work on this?.........any f22 clutch and flywheel should work just fine?
