Ok guys well the swap is almost about to happen. Around 3 or 4 weeks away. What i need to know is the OBD-1 Distributer, Injectors and ECU the only things i need to convert to OBD-1? I have a obd-1 manual P28 ecu, but i heard that it can be bridged/converted or somethin to be an auto. Is this true? And cause i'll be runnin my auto with it temporarily, should i use the cb7 or prelude tcu?
OBD-2 to OBD-1
You'll need the ECU to be custom tuned to run the car. If you know someone that can tune it, chances are they can make it auto as well. Most people don't turn a manual ECU into an auto one, but I'm sure it's not difficult. I'm running an auto P28 in my manual car right now. If you aren't having it properly tuned, then just run the Prelude ECU and TCU. The Accord TCU will give you the Accord shift points, which will be WAY too early for you to take advantage of your new engine!
You'll also want to get a conversion harness for the OBD2-OBD1 conversion.
Here's one: http://www.boomslang.us/obd2to1.htm
There are others to be found if you look for them.
also you can just get the H23 dizzy or a pre-96 H22 dizzy.
& you should use the TCU that that tranny takes.
93 Accord LX Sedan (sold)
i am using a rywire conversion harness in my 97 civic and they are great so i would suggest them and they happen to be only 70 shipd
Where are you located my friend does tuning and chipping and if your close he will tune the car and chip your ecu for auto
visit www.fourgasm-motorsports.com
For sale-Brand new stock f22a clutch and also have stock flywheel pm for details or prices
