What function has this sensor???
    Please look at the picture / link.
    Is this the Air Intake Temperature Sensor? Or what is it?
    I dont think i have the wiring on my stock f22a harness.
    Thanks!
    Accord M0DiFi3D From Norway
    Visit Website: http://www.garaget.org/?car=63883
    Correct.
    wat?
      What is correct? Asked 2 questions:P
        my f22 had a air intake temp sensor
          the picture is of an h22a engine obd1. I must know what function this sensor has...
            and that is an air intake temp sensor in the pic.
              measuring the intake temp
                Ok thanks for answer.
                What will happen if i dont use it?
                The f22a harness dont have any connector to this sensor...
                Or is there a similar sensor on the engine?
                  it probably will pull a little timing and add a little fuel to prevent detonation. if your f22 harness doesn't have one then just get a ecu schematic and pinout then just run the wires directly to the ecu. it's only 2 wires.
                    yeah should do that, but what happends if i dont use it?
                    Do you know where to find a pinout diagram for the other pins than VTEC?
                      measures what?? hahaha
                      it's for the iab's.
                      so they open and closes. the vaccume is suposed to be connect to that balck box on the bottom of the picture.
                      one wire goes to ecu. the other to switched inigtion.
                      FS: DSM turbo parts,OEM parts, and more.....
                      My Members Ride Thread - R.i.P
                        it's for the iab's.
                        it's just a little plastic probe that's held on with 2 bolts. i have one for a f22a6 for sale on carolinahondas.com right now. as for the vacuum line, it hooks to a diaphram attached to a lever that opens and closes the secondary intake. the wiring i'm not sure about the wires. one goes to the ecu and i don't know where the other goes or which is which. i've never had to wire one before.
                          the wires tell the valve when to open. yes there on a6 and h23 also.
                          its right in the swap stickies.
                            ok, so these 2 wires in the picture has to be wired directly to ECU then?
                              the sensor the arrow is pointing to isn't IAB. i'm looking at a service manual right now. that a intake air temp sensor. i'm not doubt it has something to do with the secondary intake opening, but it doesn't dictate alone. the ecu does that. the secondary intake opens based on intake temp, throttle position, manifold pressure, etc.. the sensors send signals, the ecu reads them and decides whether to open or not.
