Leaking Oil...
    Leaking Oil...
    Hey guys, I got a 92 accord lx 4door 5 speed. Lately the car has been leaking minute amounts of oil in my parking spot. I put her up and looked, and proceeded to change the oil pan gasket. The oil is still leaking , but the oil pan is clean. The valve cover gasket is good, the output shaft seals are still good. Can anyone shed some light on my predicament? I will go get an engine shampoo done within the week, but can anyone tell me where old hondas tend to leak from ? Any insight would be much appreciated.
    Thanks.
    Have you checked your dizzy seals?
    http://www.cb7tuner.com/vbb/showthread.php?t=143599
      Oil cooler, thats where mine was the last time
      NEW PSN
      H22wagon
      New project. 95 EG HB H22
      RIP
        Dizzy seals ? is that my driveshaft seals? And i dont think my car has an oil cooler, its a 5spd. Tell me if im totally wrong or should i just go back to reading my hanes repair manual lol
          Distributor O-Ring. You need to find out what section of the engine bay first that the oil is coming from like Driver Side Rear or Front or passenger side rear or front.
          -1991 Honda Accord LX H22a-
            You can also check your "oil sending unit". It the sensor above the oil filter..,
              Same, but I think the oil coolers were only on the 93 ex's? Correct me if I'm wrong.
              -Tom
              Bought From: Losiracer2
                Follow the oil... oil only travels down and back ( unless you speed in reverse). So look furthest up and furthest forward and you should find it.
                  Rear Main Seal Is Gone Were Tranny And Engine Join
                    mine was leaking behind my engine dead center and was the oil sending unit. fixed it for like $8 w/ a new part at autozone.
                      engine oil cooler, not tranny cooler. s sandwiched between oil filter and block. not sure you have one though, i have a 92 ex. think only ex 's had them. also the oil sending unit.dizzy=distributor
                      you'll love my nuts!
                        Mine Was On Me H22 Ex
                        NEW PSN
                        H22wagon
                        RIP
                          Well if you've got the Hayne's repair manual, it'll probably tell you the same things we're gonna tell you.. It should have a troubleshooting section with that in it..
                            Thanks guys, Ive been getting second opinions from every mechanic I hang around. Ive heard camshaft seal, rear main seal, front crank seal, too much stuff anyways. It is time for a TB+Wp combo so I think ima go ahead and do that in two weeks time. As far as short term plans go, friday = ,engine shampoo and its my day off work so drinking time
                              did u find leak? bottoms up!
