High idle problem??
    High idle problem??
    When the car is in park or nuetral it idles perfectly. Drive gears and reverse it idles at about 1300-1500RPM...annoying as hell sitting at the light MASHING the brake to hold it there and loud a$$ idle... F22A6 with auto tranny. Any ideas as to whats causing this? I searched some...
    *Click on photo for my MR thread
    i have the same problem but when i put in neutral i doesn't go back down >< I'm going to test out my IACV with multimeter or something tommorow.
    I just look at Haynes Manual and came across Testing TPS with multimeter. They said if it broken or loose it could cause the Car to deliver bursts of fuels from the injector and Cause Unstable Idle (PG 6-8)
    You might want to check DIY for Erratic Idle also.
      I have the exact same problem as you guys.
        Yeah, I have seen tons of stuff on the low idle or erractic idle but not really finding much on the high idle while under a load. I'll keep searching, maybe I'll bust the meter out tomorrow and test all my sensors also!!
          same issue mine will idle really high while stopped right around 1500 to 2000 but when it's warm it bounces idle and ive replaced everything i can that has to deal with idle it's annoying as hell .. im lost on it
          we ride for riding we drive for the passion we dont have money other's do .. we do this for the love of our car's ... we are ...Barcode
            try adjusting the idle screw on the left side of the the throttle body. use a flat head screw driver.
              If it is idling high just in drive gears/reverse this will not fix it, adjusting that screw will just move the idle up or down in all positions. It's storming here or I'd be out with the meter checking things...(of course I have a garage, but cannot get a car in it right now, it's full of sh!t )
                mine is the opposite. in park it iddles at 1400-1500rpm. its my FITV messin up. annoying. im not sure if that is it in your case but i found honda oem for $50. http://store.autodynamics-honda.com/hop13p2tp75p.html
                the IACV new makes me a bit sick, $142
                  i had that idle too the cheak engine light came on it was the coolent temp sensor
                    I have this problem, and I've found that if I take my foot and stick it under my gas pedal and pull up, it slows it down. I've just been too lazy to really fix the problem, that and the weather has been shit of late
                      I get no CEL with my problem. I really doubt the gas pedal pull up will work on mine, think I tried that when it first started. I may just start to swap out some sensors for extras I have laying around and on other motors. I'll keep posting with what I come up with...
                        I haven't experience the problem since my last post on this topic....WEIRD!!!!!! And I didn't do anything to the car.......
                          yup...my other car was like that and after adjust..its fine..
