CAR WONT START TURNS OVER BUT NO SPARK. ANYONE DELT WITH THIS PROBLEM BEFORE I OWN A 1992 HONDA ACCORD EX. CHANGED THE ECU.DISTRIBUTOR.IGNITER.IGNITION COIL.SPARK PULGS.SPARK PULG WIRES. I REALLY WANT TO GET THIS THING RUNNING SO ANYONE THAT CAN THINK OF ANYTHING I WILL TRY. THIS IS MY BABY. TAHNKX
I Need Help Guys!!!!!!
Main relay does fuel, not spark.
For future reference, I know you need help... but typing in all capitals is like walking into a shop screaming your problems at the top of your lungs. Rather that type in all caps, focus on making your problem clear, so people will take the time to read it and help you.
If you're not getting spark, and you're SURE the distributor, cap, rotor, wires, igniter, and coil are good... you may want to check your grounds. You've replaced just about everything that would cause a no-spark situation. Honestly, it's very likely that one or more of the replacement parts is faulty. Even brand new, sometimes that stuff doesn't work.
You HAVE actually checked for spark, right? Not just assuming that's the problem? If you haven't checked for spark, then it may be a fuel issue. In which case, Josh's advice is the best place to start. Main relay, fuel pump, fuel filter, injectors (though to have all 4 clogged would be a feat), lines.
You changed the distributor, did you hook the ignitor wires up correctly, that could cause it, and easy to make the mistake too. Where did you get the distributor? does it even still have the ignitor in it anymore? those are popular items to steal at pick a part yards, cause the whole dizzy won't fit in your pocket!
