I just bought a 93 accord lx model today it has and automatic tranny. When i rev the engine while parked the car will not rev past 3600 rpms at 3600 it starts to sputter. A lil background on the car it has been sitting about 6 months and has no muffler on it I just drove it home like that about 50 miles and it rides good as long as u don't get on it. At idle the engine shakes bit also. The car takes a bit to crank up. Tomorrow I am going to put new spark plugs and check the timing or maybe tonight i will do it. Anyone have any ideas? I can't complain though because I got the car for $800 and the body and interior are clean.
Engine sputtering
I want it to rev to redline just like most cars do. Does your car start to sputter at 3600 rpm's while in gear going down the road and while parked? If you don't have something helpful to say please read the post and move to the next.Originally posted by deevergote View PostHow high do you want it to rev while in neutral?
My alternator is good all the lights are bright. As a matter of fact the battery was dead when I bought the car we jumped it with a box and the 50 mile drive was good enough to charge it back up actually I drove about 8 miles and had to get gas and I shut it off then and it started right back up again.Originally posted by alkoholikwun View Postcheck the alternator, how are the dash lights when the engine is on and lights are on, are they faded/light in color (not bright)?
Today I changed the spark plugs and cleaned out the iac valve and still no change. I just read in one of the other posts about checking the ground by the thermostat and I just put the kids to sleep so I'm going outside to check that out. I haven't been able to check the timing because the timing light is playing hide n go seek in my garage at the moment.
I got the parts today from the junk yard I pulled the distributor with cap and wires, coil, and the iac valve. I didn't get to put it in though cause my uncles water pump had to be changed and that took till dark. The car I took the parts from I know ran I drove it in the junkyard they junked it cause they where unable to get a title for it but that sucker peeled tires from a dead stop with the automatic tranny. So hopefully I'll have a properly running car tomorrow!
